herm0016
finally getting the 72 Wagoneer done, its been sitting for a few years.
we have difs out of a 76 bronco and are going to build a 2 link system like the bronco for the front suspension. high pinion 44 for the front and a 9in for the rear. they currently have 3.23 LSD gears.
engine is be a 5.3L/6l80/mp whatever transfer case that bolts up. I currently have 33 in tires on it, but plan to go larger in the future.
with the spread in the 6 speed the 3.23 gears are not too bad.
will it work to start out? i figure ill go ahead and put lockers in it eventually.
low is 2.71 on the tcase.
grimmjeeper.com is a good calculator.
looks like with 33's i would be turning about 1500 rpm in 6th at 70 mph.
in low range in first at idle its about 2 mph and at 3000 its about 8 mph.
