- May 2, 2003
- 1,740
- 5
- 91
I installed a refurbished Corsair H100 onto my GD-990FXA-UD3 with an FX-8350 last night.
Previously I was running 4.6ghz at 1.35V with an NZXT Respire T20 with very high load line calibration and HWMonitor was reporting 70C running LinX.
After the H100 was installed I got it up to 4.8GHZ at 1.375V and +.25V to the CPU-NB with lower temps than before. It passed 10 iterations of "very high" LinX (4gb) at the same reported temps as before on air. I queued it up for 20 iterations of LinX using 14gb of memory to test stability over night.
I came back an hour later to the comp off and it would refuse to power on. If I hit the power button, it will blip on for a fraction of a section and immediately power off. I removed everything from the case and disconnected anything unnecessary to rule out shorts to no effect. I tried another known good power supply and no change either.
I have tested the video card (Radeon 7970), RAM (4x4gb Crucial DDR1333), and power supply (Seasonic X-650 gold) successfully in another system.
At this point my thoughts are that something blew in the power stage on the motherboard. I bought the board used on craigslist a few months ago so I'm unlikely to be able to get an original invoice for an RMA.
At this point, I'm thinking of just paying through the nose for a 990FX Sabertooth to know I'm getting something of quality. Any other suggestions? I use the box as a VM testbed, folding@home cruncher, video encoder, and as a secong gaming system when a friend comes to visit.
