D batteries aren't special except for capacity (same voltage as AAA and AA). They sell D-size shells that you can put AA rechargeables in if you want to try that route.
I believe you can get adapters that let you load AA's into a D housing...call it the 'WonderBat,' perhaps. :hmm:
D is still 1.5v, so one AA battery, or two or more in parallel, will run the same device. The smaller batteries just have less capacity.
Much, much less capacity.
How much voltage are you looking for? The cell voltage for LiFePO4 is 3.3V (just a bit above 2 alkalines in series) and that's with a VERY flat discharge curve and abuse-tolerant chemistry.
If you're going to put a smaller NiMH or NiCd battery in a D shell, at least get Sub C's.
Yeah, just realized that too. D cells can be from 5000 to 10000 capacity.
AA's are like 2500 at best. 1/4th that.
I've been thinking lately...it shouldn't be that hard to get like a portable rechargeable outlet for any electronic, no? Basically, like take a laptop battery cell, put it in a box, connect it to power outlet. Recharges when plugged in. Gives power when unplugged and has power drawn from it.
CR123 Lithium or go home![]()
How many batteries does it take?
Oh man...old memories just stirred, of using a 120mm Panaflo computer fan and a lead acid battery, for a similar purpose.![]()
18650s will send those puny CR123s crying home to mommy.
Only D cells I have is for my Maglite and it's an LED so hasn't required a change in years. I wonder how long a 6D LED Maglite would last...
I'm surprised that no standard has been made for lithium-ion batteries so that every device doesn't need their own custom, proprietary battery.
