Gateway Power Supply.....can I substitute something??
NonTechi
33
My old Gateway PII 233Mhz needs a new power supply; all I know is that the old one was 200W and ATX. Anyone know where I can get one or substitute one, ie, will a 145 PSU do the trick? BTW, I did try Gateway technical support, they don't have any (surprise, surprise......). I also have a feeling the I'll need a "micro-ATX", but I'm not absolutely sure.......thanks for any info.
Viper22
As far as i know GW is not out of those Power Supplies as I get them in all the time for customer units. PM me with your Serial # and i will look up your system and see what you need.
Viper22
Wolfie
You shouldn't need anything special unless of course it is a mini ATX. But a PS with 200W should do the trick. And GW always trys to get you to buy a new machine. So don't believe them if they say you can't get one. They are everywhere. Good luck....
Wolfie
Joony
7,654
a normal standard ATX PSU won't fit in, trust me i've broke my PSU before and had my spare normal ATX one hanging outside the case...while the replacement comes
NonTechi
33
Yeah, that's why I get the feeling that I'll need a micro-ATX, although I may have to drill a hole or two in order to screw it in place. You would think that a company like Gateway would at the very least tell you where to get a replacement if they don't have it........live and learn. Thanks for the responses everyone, you guys are the BEST!!
lowtech1
4,644
Offten it is the fan that failed, therefor test the PS to see if it is still good then replace the fan if it is aplicable.
CZroe
24,195
857
Most Micro ATX cases still use ATX power supplies. Micro-ATX PSUs have a fan on the inside positioned over the processor (PSU is sideways) but I have seen many cheap generic cases blanketing the CPUs with regular PSUs (Looks like they need the Enermax dual-fan kind). Micro-ATX PSUs are VERY distinguishable! The are much smaller, full of vent holes in the rear (Because the fan over the processor is usually the only fan), & have a fan mounted on the inside of the case over the proc. 200w ones are rare, but I saw one that said it was a generic eMachines replacement (Is eMachines proprietary in any way?).
