Gateway PC and power supply
MoFunk
4,058
A friend of mine from out of town called and said that his computer will not turn on. I have no idea how to troubleshoot this over the phone. I am thinking power supply. He says it's a gateway but is not sure what model, it's about 3 years old. Question is do Gateways use a proprietary PSU or can he buy a new one at the store and replace it? I dont want to suggest that and have him fry anything. Thanks.
lenjack
2,706
7
I'm not positive, but I think the power supply is standard. Best wait for other responses.
BofRA
2,362
Just make sure its a atx and not an at power supply. Three years ago some manufacturers still used at power supplies for some reason.
Freewolf
9,673
True, I hadn't throught about that
redbeard1
3,006
It should use a standard atx power supply plug-in, but depending on the size of the case, it may take an odd sized version.
sswingle
7,183
45
Gateway most definately loves to use odd sized power supplies. Fortunately, all I have seen are smaller, so all you need to do is get a drill and make some new holes. I have done this on three or four gateway cases so far...
MoFunk
4,058
Well good news! He called and told me that he went to Best Buy, got a new PSU and all is well! Thanks guys!
