I just plugged my DVI cable into my monitor after exchanging my video card, and I can't get any signal to go to my monitor. What am I doing wrong? If I use a VGA cable (with a VGA to DVI adapter, as my card has 2 DVI ports) it works.
I'm going into the display manager, and trying to enable my monitor, but it just blinks a few times on this monitor, and then nothing happens, and the box unchecks itself.
Connect to the VGA port only and boot.
Make sure your resolution is 1680x1050.
Make sure the refresh rate is 60Hz.
Then, power down the PC.
Disconnect from the VGA port and only connect to the DVI port of the monitor and boot.
Process completed, to no avail. Interesting note though. When I plugged the VGA back in, the video mode had reset itself to the meager 800x600 resolution.
You can go to the Gateway web site and fill out a form for technical support. You will need the serial number for that. They will get back to you in a few hours.
