Gas stove oven burner issues
noob25002
95
Hello,
Recently cleaned a stove, things got messy, had to remove and clean the oven burner to clean it. Older model. Used baking soda paste and vinegar after.
When starting it I noticed a yellow flame around the thermocouple. With an endoscope camera and on the other side of the burner at the tip.
After cleaning I started it up and after around 1 minute the gas monitor started to pick up readings of 200ppm and climbing. In the oven chamber it was over 600. Did not look for yellow flame.
Reassembled and now there is a spike of ~30ppm once every 2 minutes. The yellow around the thermocouple flame is still there, haven't checked the other side. Carbon monoxide monitor did not detect anything.
There is some rust on the burner, but wholes seem clear. I could try to clear rust with white vinegar, but I don;t know how I could get inside the burner to scrub it, and it needs a coat of anti rust otherwise it will rust again?
Has it been reassembled incorrectly?
Does rust need to be removed?
Moved from OT.
admin allisolm
Reactions: brianmanahan
Nov 17, 2019
13,316
7,886
How old is the oven?
I recently replaced my nearly 20 year old range and it made all kinds of difference in cooking and energy use. It had gotten to the point where I really couldn't even use the oven since it wouldn't maintain heat properly.
noob25002
95
I don't know, maybe 10 years. I am going to replace it since the gas meter is detecting something when using it.
