Gas grill replacement parts
Discussion in 'Off Topic' started by SAWYER, May 3, 2012.
  1. SAWYER
    SAWYER Lifer
    Apr 27, 2000
    16,640
    32
    I have a gas grill I have been using for a few years now, now the burners(assuming that is the name) hardly put out any flame at all. The fire barely comes out of them and not even all the way around the burner, just towards the front. Can these be replaced?
  2. PottedMeat
    PottedMeat Lifer
    Apr 17, 2002
    11,952
    242
    check for blockages in the nozzles, like insect nests/eggs
    replacement is kinda a final option
  3. Rastus
    Rastus Diamond Member
    Oct 10, 1999
    4,706
    Go to Lowes and pick up a generic kit for it. There's a whole section of replacement parts for gas grills.
  4. MagnusTheBrewer
    Jun 19, 2004
    21,381
    379
    Clean the burners.
  5. sdifox
    sdifox No Lifer
    Sep 30, 2005
    68,014
    2,628
    steel wire brush it first.
  6. WackyDan
    WackyDan Diamond Member
    Jan 26, 2004
    4,643
    29
    What kind of burners? Are they steel? Then they are probably rusted and need replacements... I order mine online though I will never buy a grill with steel burners again...
    Are they brass? Clean them.
  7. KK
    KK Lifer
    Jan 2, 2001
    15,887
    yeah, clean the burner like everyone has mentioned then if that still doesn't do it, maybe the regulator is fucked. Or maybe your tank is empty.
  8. EagleKeeper
    EagleKeeper Discussion Club Moderator<br>Elite Member
    Staff Member
    Oct 30, 2000
    42,600
    First ensure that the tank is not empty
    then get replacements if it looks at all rusty.
    if that does not work - replace the regulator.
    all stated above by KK - but the order is cost and probability
  9. Gillbot
    Gillbot Lifer
    Jan 11, 2001
    28,785
  10. robphelan
    robphelan Diamond Member
    Aug 28, 2003
    4,052
    had a similar problem last week .. i cleaned the burners and bought a new regulator - works like a charm again
