- Aug 3, 2005
- 9,916
- 2
- 81
I got some shudder and simply sanding with Garnet paper should solve it if its just pad material
If you look into the specifications it says "Material Aluminum Oxide"
So uh what the heck?
Now for instance, http://www.harborfreight.com/7-pack-100-grit-garnet-sanding-sheets-92742.htmlIf only a small amount of material has been transferred i.e. if the vibration is just starting, vigorous scrubbing with garnet paper may remove the deposit. As many deposits are not visible, scrub the entire friction surfaces thoroughly. Do not use regular sand paper or emery cloth as the aluminum oxide abrasive material will permeate the cast iron surface and make the condition worse. Do not bead blast or sand blast the discs for the same reason.
