Originally posted by: MustISO
I'm looking at the same brand but a nicer model, the builder did not install a very good one. It looks pretty basic from what I can see. Just need to make sure I turn off the power. Is turning off the light switch enough to say the line isn't hot anymore?
This is typical of cheap units.
Replacing one is easy..... for me.
Turn off circuit breaker. Disconnect wiring if hardwired, unplug if it has a plug.
Remove drain piping. KEEP THESE. If you need to replace them due to wear, it's easier to match replacements.
Remove disposal. This unit will be heavier than you anticipate, since you're likely to be in an awkward position (kneeling, on your back). A helper is handy here.
The nut that holds the drain on may be rusty. Spray w/ WD-40 before trying to remove.
Dry fit piping for fit before installing.
Replace disposal.
Re-connect piping to snug tight.
Re-connect Power.
Run water through and observe for leaks. Re-tighten if any are noticed.
Relax and enjoy a cold :beer:.
< Singing "real men of genius".......:thumbsup:
