edro
just for your reference OP, I have had two Insinkerators ( low end models, nothing fancy) one for 8 years in my old house and my current for 2 years in my new house. I have never had those bladed get stuck. I would definitely consider calling them to see if you can get a replacement. I agree the allen wrench only turns the motor which is free in your case. It looks like the blade is hitting the bottom plate portion of the unit I wonder if that rivet/screw is somehow bent ?
Right. It's like there is NO clearance between the swivel piece and the base plate.
There are just a few little swirl marks on the base plate where the blades had spun before, but I would expect to see many more.
It makes me think they got jammed early in its life or were too tight from the factory.
I'll be replacing it, but will send it back for warranty replacement. I need a new one for my rental anyway.
