"Garage" or other Forums also-probably: devices with built-in rechargeable batteries: "Vehicle cassette-player Blue-Tooth Adapter"
BonzaiDuck
16,792
2,122
Last year, if you visit the "Garage" Forum, I posted a series of articles about bringing my 1995 Isuzu Trooper LS into the 21st century to make it an "Android Trooper". My [digital!] OEM vehicle audio-receiver is mated with two Blue-Tooth receiver devices: "Tape ' PLAY" and "FM/FM2". One communicates with the OEM receiver via FM transmission; the other using the long-standing traditional device of a cassette tape-player adapter. So I have my standalone MP3 player -- built into the dashboard transmitting to -- say -- 92.5 as a preset among five or ten radio frequencies; and I have my Android (9.0) 7" tablet mounted to the dashboard and transmitting to the other Blue-Tooth receiver. If I keep the sound files in sync and well-updated, I can queue up three sources of music including the 12-CD changer, so that I only need to push a single button on the OEM receiver to switch from one album or performance to another. This makes for safer sound-track control with some decent options that don't require pushing a button more than a very few times so you can keep your eyes focused on the road. I can run Google Maps, simultaneously to [rear-view-nightvision] camera, front-camera/recorder, 5-band equalizer with categorical presets (like "Folk" or "Classical"), and the Pulsar Player for sound files. Voice recognition; voice navigation. I can switch the sound-file source and device with minimal button manipulation and more attention to driving. Other times, one may want to pull over to the shoulder or rest-stop to find different albums or artists to play, but the distraction takes considerably less time than the cycle of an intersection traffic light.
Choice of a tape adapter led me to buy three or four of different makes -- the traditional design with the 3.5mm stereo phone plug, a Bluetooth model that could not be in use while charging, and the [Heibeige] iTape model, which I finally chose to install semi-permanently. It seemed that the time the second device would take to need recharging was a bit short of their 6-hour spec. I wanted to be able to run the device as connected to an active USB QC charger -- also installed in the dashboard to feed both the Android and the iTape. The USB cable is thin, and easily hidden or stowed away neatly on the dashboard so that it is almost not visible.
The iTape's only other "dangling cable" contribution is merely a tiny 6" wire with however so many conductors attached to a rubber-dongle with three push-button switches: "+", "-" and [pause/stop/[on/off]]. Again, the cable clutter doesn't exist but for a 2" loop between iTape and dongle. I used two-sided foam tape to secure the dongle to a proper location on the dashboard.
THE PROBLEM: After a year of normal use, the battery of the iTape does not seem to hold a charge for very long. It seems to stay on while BlueTooth is paired, but I need to test how long that might be. Otherwise, switching "ON" the dongle only activates the BlueTooth for as long as you hold down the button after the required 5 seconds. Yet, when The USB charging switch is "ON", the iTape functions just fine -- so far.
One friend and electronics veteran told me the Chinese don't use good batteries. He even suggested getting a replacement for the device (They're about $28).
I'm thinking -- debating -- as to whether I should attempt to disassemble a unit and then locating and possibly replacing the battery.
But -- what do you figure? There's an even chance their battery is soldered to the rest of the assembly. I only have certain soldering equipment, my eyes are 74 years old, and soldering something that needs a microscope to do so is . . . beyond my skill-set or desire.
How long can I count on the device working properly as long as the USB power is active? It seems totally reliable this way so far, and I don't need the battery-driven capability. Or, I could simply replace the device with a 3.5mm phone connection to my Android.
I can pair the Android with the MP3 player via Blue Tooth. But the player has a volume limitation just short of my listening preferences. Still, it is nice to have expanded use of the cassette player of the receiver, and the sound quality is superb -- supposedly noted in reviews of the Trooper still available on the web.
I'm just wondering what options I have to restore the battery function of the iTape, or merely continue using it with the USB active power.
More than a year "sheltering-in-place", carefully scheduling trips out in public, wearing masks . . . This is what it's come to: fretting over a $30 cheap Chinese Bluetooth adapter. . . . . I could get by fine just using the other one . . . .
SamirD
1,489
276
www.huntsvillecarscene.com
I'd love to see the thread where all your work is documented, so please post that. :)
So I would just continue using it as-is. Once the battery completely gives out and won't conduct anymore it will probably die. And at that point, going with a wired solution would be best long-term unless you got some benefits from the BT and dongle.
BonzaiDuck
16,792
2,122
I'll oblige you -- your interest in this seems genuine. Just to comment before I post a representative Anandtech link, I've discovered that you can search widely for several products which solve some problem or define some project, and the range of outlays for such an item vary widely. For instance, some cassette adapters of the conventional variety may have a price of $10; the tape-adapter I'm using (the iTape/Heibeige) is more like a $30 item. In other aspects of my audio makeover, I had originally only had ambitions for an MP3 player, but the $25 unit I purchased also has a BlueTooth receiver -- switchable between BT and the MP3-player's access to a USB thumb-full of MP3 files. And so one may wonder how long these devices will last, as we've been discussing.
I think there were more like two or three threads I started last summer as my project developed and continued, but this one says it all:
CAPTAIN VIDEO AND THE ANDROID TROOPER -- A Borg Redundancy
From the photos, you might miss the fact that some "fine woodworking" effort went into the MP3-Player's installation, unless I point it out.
As for an answer to Mindless1 -- You know me! I can't help myself! The fingers never stop!
OTHER OPTIONS
As I said, you can search widely, find a solution of a certain kind, and hope that the modest expenditure will suffice for many years.
I recently came across this "iSimple Tranzit" adapter kit, with a price ranging from $75 to $95. Maybe the Tranzit would have a greater or more reliable lifespan. It connects to the OEM receiver the same way that my MP3 player does -- through FM transmission to a pre-selected frequency/channel. It is somehow wired in such a way that it eliminates all other FM reception when the Tranzit is turned "ON", allowing for use of conventional FM with the Tranzit "OFF". With the current MP3 player (see the photo with the walnut panel and the device with two dials and blue LEDs), one must select a channel (or channels) for presets which are available, and this may change for a long-distance drive. But I've never experienced any of the bothersome interference from radio-stations, etc. on my chosen pre-select.
And -- after the experience of playing around with these $25 products -- I might again worry that this special feature of the Tranzit might eventually malfunction. The whole point of it -- with the Tranzit or a simple USB dongle wired into the the OEM receiver -- is the need to pull some dashboard panels and access either the entire OEM receiver (removing it for disassembly and soldering), or the antenna connection to the receiver. The cassette adapter and the MP3 player avoid all the tedium.
FOOTNOTE: Look for the photo which exhibits a bright red dot on the dashboard. The red dot is part of the iTape/Heibeige unit.
Also, understand that I wouldn't have done any of this but for the fact that I don't want to modify my dashboard to fit a double-DIN $1,000 receiver with an Android LCD screen. Further, the original OEM package included the ISUZU 12-CD changer, which I"d found new as replacement for the old one at about $80 on EBay. It won't work -- or would require some sort of modification, anyway -- to make it function with a new receiver. So all the OEM audio equipment still functions, and thus -- the adapter devices.
BonzaiDuck
16,792
2,122
My thread has persisted in silence since my June 23 post. I yet think an UPDATE is timely and almost worth my trouble.
I have yet to dissect the subject i-Tape Bluetooth w SD-card input cassette adapter -- link already provided.
I find more than a few of these Chinese companies hawking what one might suspect as production-runs from another company's factory. They may differ in such things as "programming for a 2" LED MP3-player display", but they might otherwise be physically identical.
So I eventually found another Amazon offering that was not that of "i-Tape" or "Heibeige", and it featured an identical appearance, like the dongle-switch "<<", "On/Off-Pause" and ">>" buttons and plastics.
Someone in "customer reviews" reported a similar problem to that which I encountered with the "Heibeige" or "i-Tape" brand. Another reviewer advised users to dis-assemble the basic casette-player case, disconnect the battery (howsoever you might find it), and then reconnect the battery.
I'm going to swap in the i-Tape I bought as backup, and -- finally -- take apart the original unit. However, before I proceed, any comments or discussions that might argue for or against the logic and wisdom of the advice mentioned above . . . . . are eagerly encouraged.
Bluetooth transmits information from the i-Tape to my Android (dashboard) tablet, so that I can read the battery-charge level of the i-Tape on the Android. It currently says "100%", but I'd seen various values when I'd first started using it. After all, if you are easy putting a battery-driven device into a state of near-perpetual charging, you might not check the "Settings" menus and relevant item.
I'm just trying to imagine what is going on with the device. All these devices I've seen in recent times appear to have certain "smart" features that don't have adequate description in the "installation" or "user's guide" -- usually in slightly-broken English common to Chinese product documents.
I'll be checking back to see if others offer some additional thoughts, but I'm going to do it within the next few days. At least -- test the new unit. The testing might then give way to "dis-assembly" to occur over another period of days.
