Both my garage doors work good. No noise, no jerking, and easy to go up and down. I just noticed that when the door is down, there are gaps in two of the garage door springs that I don't believe were there before. The door springs are easily 6 or 8 years old. I'm thinking that it is probably time to replace the springs. I have a few questions about it.
These are the safety springs that are near the top track and has a safety cable running through it. Not the torsion springs.
1) With the door up, it appears there is no pressure on the spring and it should therefore be an easy swap to put new ones in.
2) Are all garage door springs the same? Do I just go to Home Depot or Lowes and buy springs? Do they come in different lengths or tension? Are there Heavy Duty Springs?
3) Any tricks to installing these springs? They actually look pretty easy?
