Garage door shakes when it closes. I used WD-40 on the track, but it didn't help
JEDI
29,391
2,738
for months i noticed that my garage door shakes when it closes.
so i finally got some wd-40 and sprayed the track. but it still shakes.
suggestion?
THX
spaceman
17,616
183
suggestion?
THX
realign the track
MikeMike
45,885
66
suggestion?
THX
make sure the tracks are straight? the wheels are straight etc?
maybe its the spring?
freebee
4,043
Door is not balanced. Balance door.
Lube using lithium/or heavier weight grease.
JEDI
29,391
2,738
the garage used to come down straight.
realign the track? what do you mean? how?
how did the door become off balanced? and how to balance the door?
why would the wheels/track become crooked?
mobobuff
11,099
To prevent binding, tracks must be properly aligned to guide the rollers. If one or both of the tracks needs adjustment, loosen its mounting bolt and use a hammer and a wood block to persuade it in the proper direction, then retighten the bolt.
spaceman
17,616
183
buildings shift and settle.
is it a new garage?
ive rarely operated a garage door let alone own one, but i do know they operate on a track mechanism and if it is shuddering as you close, common sense points to the track being misaligned.
JEDI
29,391
2,738
no. 10 years old.
it might have been shaking for years for all i know. i never look when it closes.
i just noticed a few months ago when i sat in the driveway when it closed.
i finally did something about it today (wd-40).
how do i know which side is off balanced? and how do i know when it's the proper alignment? or is it just trial and error?
Ornery
17
Disconnect the opener from the door. There should be a pull chain to do that. Lift the door to waist level and let go. It shouldn't go up or down. That's balanced. See if one side is higher than the other, that it's level. If not, one cable needs to be adjusted. If I were you, I wouldn't mess with it.
Lubricate the roller bearings in the wheels with straight 20 weight, non detergent oil, not WD-40. Inspect all those bearings to make sure they're intact. Sometimes the race gets destroyed, which may also be your problem. Those rollers are cheap and easy to replace.
Dabappa
151
Also check the pulleys that the counter-balance cables run through.
The bearings went in mine and caused problems similar to what you described.
Replacements should only be a few bucks at the hardware store or your favorite ubiquitous orange home center.
Good Luck,
JEDI
29,391
2,738
don't mess w/it? it wont lead to any problems?!
vailr
54
10 years old.
It's not until your 3rd post that you mention that an automatic opener is also involved.
It's more likely that the garage door opener mechanism is worn out.
Such as: the plastic gears are worn out.
Or else the metal bearings are bad, worn drive gear, loose drive chain, etc. (depends on the specific brand and model).
Ornery
17
JEDI
29,391
2,738
those springs broke twice on me in 10 yrs.
i replaced them (in pairs) w/replacements from home depot. each time i got a stronger set of springs, thinking it'll last longer. (from 115lbs to 125 to 140.) (extension springs)
