- Apr 20, 2009
- 3,793
- 1
- 81
How appropriate for the garage?
Anyhoo, worked on my garage door opener on the new house this weekend. Basically I have two separate openers, and the single side we've been opening manually as the previous home owner apparently tried to install it on their own, clearly not having any kind of an idea on basic concepts (IE - screwing into studs, and not just drywall).
I've gotten that part cleaned up, and the mounting brace is secured into a stud in in the ceiling. The brackets are a bit fudged up because of their previous attempt to install it, but it is secure.
It seems I am 90% of the way there, but my only remaining issue is that when the door is closing, any time it stops, it reverses and opens back up. So whether it hits the floor, or whether I stop it with the button, it pauses for a second, and then starts to open back up. The only way to get it to be somewhat closed is to let it go to the floor, and then stop it on its way back up. At this point, about the best I can get is 3-4 inches of open space on the bottom.
I've checked the sensors, and the path is clear and they properly register blockage when I put my hand over the sensor, so that ain't it.
I've adjusted the force quite a few times, but I seem to have it about right. It will now close and stop when it gets to the ground, without binding and twisting the motor rail. In other words, if I adjust the force up any more, it will try to force the door through the ground, and start twisting. Anyhoo, the force is set right, as it closes to the floor without binding. Only problem is, when it successfully closes, it immediately re-opens.
I think the obvious solution is that the close distance knob doesn't seem to be attached correctly (may have to take it apart to get to that). But that still doesn't explain why it reverses when I stop the closing process when the door is halfway down. IE - I stop it 3 ft from the floor with the button, and it stops briefly, then opens back up.
So, any ideas?
So, any ideas?
