gamma problem
ANEO
54
i got a geforce 2 mx a few days ago, i've set it up and found out that i can't adjust gamma for opengl or direct3d. i have the latest detonator drivers and those don't have it either.
any ideas, or tweak programs?
BTW i have geforce tweak but theres no way to adjust gamma there either.
paruhd0x
3,100
What game? I know in HL and in Q3A you can adjust it majorly with some variables..
BFG10K
22,709
3,002
Just use the normal gamma slider and 3D games will automatically use that setting. You can also use nVidia's quick-tweak control panel to quickly switch to pre-selected gamma levels.
BFG10K
22,709
3,002
It's part of nVidia's drivers. Go to the Additional Properties section and click on the "Taskbar Utility" tab. Simply check the option to display it in the Taskbar.
