- Oct 9, 1999
- 17,627
- 5
- 81
For some reason, with nVidia video cards, the monitor isn't bright enough at default settings even with the monitor's brightness turned all the way up! I have a Samsung 950p monitor and love it, so don't even consider mentioning switching monitors
Anyway, to compensate I just set the gamma in nvidia's control panel to 1.4 and everything looks fine. However, when I go into a game, and come back out, my gamma is reset back to the default (1.0) and I have to manually go back into the control panel and switch it again! Is there any way to fix this? It's not just a problem with one set of drivers either, I have had this problem as long as I can remember (at least 4-5 driver revisions for sure).
Also, when using TV Out on my GF4, the brightness is way too high on the TV. Black is a gray! Sure, nView lets you adjust the colors differently for each display device (in my case, the monitor and the TV out), but when it goes into a game it resets and goes super bright again. I am not going to adjust my TV settings either....it's calibrated with Avia and it set 100% accurately to NTSC standards. I spent a good hour calibrating the damn thing so DVDs are flawless.
So basically, I can get my monitor and TV looking like I want, but when I enter any 3d accelerated game it gets too dark on my monitor, and too bright on my TV! Is there ANY way to lock this stuff?
TIA
edit: i'm using WinXP
TIA
