Gaming rig will be built soon, please give advice.
mOeeOm
2,588
mOeeOm
2,588
I know, that case is out of stock :p I would rather have this system built very soon and I like the SLK2650.
Ike0069
4,276
I'm not sure that's a very good choice of RAM for that MB. I know some people use Corsair VS RAM in their DFI witn no problems, but many others have had issues.
I would suggest OCZ RAm for that MB.
I really like the MB/CPU/VC/PSU. Not a big fan of that case but that is toatally personal preference.
I give it a 8/10.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
Oh, I see.
A sonata II would be significantly cheaper and should be more than enough for your power requirements too...
Yuriman
5,530
141
I'd probably go with a different cooler, perhaps the Scythe shogun or TT Big Typhoon if your budget allows it. Also, I'd MUCH rather have a 4200+ dual core than a single 3700+ in any situation, can you stretch your budget to get one?
mOeeOm
2,588
Oh, I see.
I'd rather be safe than sorry :p So I got a very powerful PSU.
mOeeOm
2,588
Naw, too much, because after taxes and shipping, it will come out to $1680, just inside my budget. The X2 you're suggesting is $300+ more :(. I would rather wait for X2 to get cheaper.
