- Oct 18, 2012
- 3
- 0
- 0
Hey everyone,
I'm thinking of buying a new desktop from Cyberpower, but I have a bunch of questions that I want to get cleared up first. (I have tried to do as much research as possible before coming here, but could definitely use some help)
As of right now, I'm thinking of going with a customization of the Black Pearl.
The current specs are:
CASE: Azza Genesis 9000 Full Tower Gaming Case w/ 2 x 230mm fans, 4x Easy Swap HDD, Dual Power Supply Support, & front USB 3.0 Port
CPU: Intel® Core i7-3820 Quad-Core 3.60 GHz 10MB Intel Smart Cache LGA2011 (All Venom OC Certified)
COOLANT: Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Single Standard 120MM Fan)
HDD: 2TB (2TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD (128GB Sandisk Sata III Boot Drive + 2TB Single Drive Only)
MEMORY: 16GB (4GBx4) DDR3/1600MHz Quad Channel Memory (G.SKILL Ripjaws X [+12])
MOTHERBOARD: (3-Way SLI Support) ASUS P9X79 LE Intel X79 Chipset Quad Channel DDR3 ATX w/ UEFI Bios, Remote GO!, 7.1 HD Audio, GbLAN, USB3.0, SATA-III RAID, 3 Gen3 PCIe X16, 2 PCIe X1 & 1 PCI (All Venom OC Certified)
POWERSUPPLY: 850 Watts - Thermaltake Smart Series SP-850M 80 Plus Bronze Modular Power Supply [+59]
VIDEO: NVIDIA GeForce GTX 670 2GB 16X PCIe 3.0 Video Card [+186] (Major Brand Powered by NVIDIA)
WNC: 802.11b/g/n 300Mbps PCI Wireless Adapter Network Card [+26]
COST: ~$1500 Prebuilt
I have several questions ranging from important to not so important:
1) What do you think of the current setup? Is it worth the price if I am not building it myself?
2) I can only seem to find mixed reviews on whether to go with 2 lower end GPUs in SLI or one higher end video card. I will be playing on one monitor, a wide range of games such as BF3, Farcry3, Watchdogs, Bioshock, Arma3, Crysis3, etc.
Would it be better to go with the video card i have selected (GeForce GTX 670 2GB) or better to have 2 GTX 660/650s 2GB running together?
Also, the card I currently have has these options:
EVGA Superclocked
EVGA FTW Edition
Are either of them worth it for about an extra 50 bucks?
3) I have the option of getting everything factory overclocked from the start for a little bit of extra cost. I'm not decided on overclocking as of yet since there are so many mixed opinions. I can either get "Pro OC (Performance Overclock 10% or more)" or "Extreme OC (Extreme Overclock 20% or more)" or nothing. Would you recommend I get either of these with what I have?
4) This ties into my overclocking question. What power supply would I need if I do overclock? if I don't? I figure 850W is enough for anything but what do you guys think?
Out of these 4:
800 Watts - Standard Power Supply - SLI/CrossFireX Ready
800 Watts - Standard 80 Plus Certified Power Supply - SLI/CrossFireX Ready
850 Watts - Standard Power Supply - SLI/CrossFireX Ready
Is the 80 Plus worth it? which would be the best option?
5) For RAM, which option would be best?
Corsair or Major Brand
G.SKILL Ripjaws X (All Venom OC Levels Certified)
Patriot Viper 3 Intel Extreme Masters Edition (All Venom OC Levels Certified)
Kingston HyperX (All Venom OC Levels Certified)
I have currently selected the Ripjaws.
6)Last question: is it worth getting an additional 60GB SSD for $80? In your experience does it really speed up anything you store on the SSD vs the HDD?
Thanks for all your help guys. I really appreciate it. I'm just really trying to understand what I am doing before I make any random decisions!
EVGA Superclocked
EVGA FTW Edition
Out of these 4:
