Because BLAIN said so:
1. What YOUR PC will be used for.
<<Gaming
2. What YOUR budget is.
<<less than $1500
3. What country YOU will be buying YOUR parts from.
<<USA - probably NewEgg.com
4. IF YOU have a brand preference.
<<INTEL, NVIDIA
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
<<No
6. IF YOU have searched and/or read similar threads.
<<Yes, but I could find a thread that answers my questions exactly.
7. IF YOU plan on overclocking or run the system at default speeds.
<<DEFAULT
Thanks to all who take the time to read this and respond. Also, I'll be getting a generic DVD burner and a cheap 250gb WD Caviar HD to round out the hardware. I'm fine with on-board sound (if you think the mobo is not a decent one) and I'll be installing WinXP.
Questions:
edited: Fixed E6600 to Q6600 and fixed the link to the Q6600 (was to the E6600). Thanks to DSF for correcting my Q6600 mistake.
<<Gaming
<<less than $1500
<<INTEL, NVIDIA
<<No
<<DEFAULT
- CASE = Antec Sonata III Black 0.8mm cold rolled steel ATX Mid Tower Computer Case 500W Power Supply
- CPU = Intel Core 2 Duo E6850 Conroe 3.0GHz LGA 775 65W Dual-Core Processor Model BX80557E6850
- MOBO = ASUS P5K LGA 775 Intel P35 ATX Intel Motherboard
- RAM = CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400C4
- VID CARD = EVGA GeForce 8800GTS SSC 640-P2-N829-AR Video Card
Questions:
- If I decide to go SLI with another 8800 vid card, will the 500W PS be ok or will it be underpowered? If underpowered, what case + PS would you recommend?
- Which processor will be better today, in 2 years, in 5 years? The one I have listed above, or the Intel 2.4 quad Q6600??
- Will the E6850 CPU require a bigger PS? Will a Q6600 require a bigger PS? What if I do an SLI config with 2 8800s, will either processor need a bigger PS due to the draw from both vid cards?
