Hi, about 2 years ago I used this forum for help with putting together a gaming build that I was very happy with (and had a great time putting together on a warm summer day, still remember the feeling 🙂). I am happy to see those who helped still post on this forum helping other novice builders like me. Im about to build my second third and fourth computer (all identical) so I wanted to come here again for advice on parts.
1. What YOUR PC will be used for.
strictly gaming
2. What YOUR budget is.
500 per computer including case (not including monitor, mouse, keyboard, OS)
3. What country YOU will be buying YOUR parts from.
usa
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
I dont know know much about this stuff
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
no parts
7. IF YOU plan on overclocking or run the system at default speeds.
not sure what this means but the games i will play are Diablo3, Path of Exile, Guild wars 2, Dota2. I would like to run them all on high settings, if I have to increase the budget to do that I will consider it.
8. What resolution, not monitor size, will you be using?
I would also like to take your advice on a good gaming monitor up to around $300 (no need for 3d)
9. WHEN do you plan to build it?
2-3 weeks
Thanks again everyone for your help.
strictly gaming
usa
no parts
2-3 weeks
