Gaming Pc help! Feedback/Opinions
Status
Not open for further replies.
1. What YOUR PC will be used for. Gaming and other daily tasks
2. What YOUR budget is. £600/£650
3. What country YOU will be buying YOUR parts from. UK
4. IF YOU have a brand preference. No preference
5. IF YOU plan on overclocking or run the system at default speeds. Default speeds
8. What resolution, not monitor size, will you be using? 1920x1080
9. WHEN do you plan to build it? When I get the right parts together
Status
