Gainward Geforce3 Ti200 problem
khayyam
Hi guys, I hope somebody has a magic fix for me!
I have a system configured as follows: ECS K7S5a, Athlon XP 1800+, 512 pc133 crucial, audigy, enermax 351 watt PS, WinXP. I have been running happily like this for some time now, using my trusty Elsa Geforce2 GTS. I got a Gainward Geforce3 Ti200 to put in there, and it seems to have been a mistake. With the drivers supplied by Gainward, both Half-life and RTCW hang the system as soon as I start either one up - before I even get to the game menus. With the newest detonators, the games work fine through the menu system, but once I try to actually start a game, the screen blanks - the monitor reports that there is no signal. However, the system isn't frozen; if I type ~exit to get out of half-life, windows comes back to life and everything seems fine. Also, one other thing - when I try to do video playback in Windows Media Player, it just rebooted the system with no warning whatsoever. Neat, huh? Any ideas, anyone? I put my GF2 back in, and everything works flawlessly.
To complicate matters further, I'm not sure whom to turn to if the card is bad. I bought it from newegg, who says that I should contact the manufacturer, and gainward says that all support is through the reseller. Do I have any recourse (provided I can't get it working) other than returning it to newegg and paying the 15% restocking fee?
First off, only use nvidia-supplied drivers. Everyone will tell you that. Anyways, there's probably some remnants of either the gf2 or gainward drivers floating around in there. A nice format and reinstallation of windows and then the detonator drivers should fix you right up.
mmm... what fun. I've got an extra drive around here, I think I'll toss that in and do a fresh install and see what happens! I hope you're right!
The Gainward Expert Tool software doesn't like XP. Also, have you installed all the latest updates for XP? MS regularly releases compatability updates that may or may not help you.
Unistall all the Gainward crap software and drivers, install the latest nvidia drivers - be sure any anti-virus software is not running when you install the nvidia drivers - and see if it works then.
If that doesn't work then I'd say it's time to think about a fresh Windows installation.
Yeah, I poped a spare drive in and did a fresh install on it, and everything works fine. Grrr.... stupid windows/nvidia/gainward. At least it works now!
