Gainward connections problems
HTcracker
33
I just recieved a new Gainward GF4 Ti4600 yesterday, I went to install it in a new,never started computer I just built
for my teenager and I find that it has two ports that I am not familliar with. They are both scribed "DVI" on the mounting plate
(digital video?)are slightly larger overall then a standard serial port and have 24 pins on one side 4 pins seperated by a small flat clip/bar
on the other side. The card came with 2 adapters to connect a serial cable, but my problem is that with the adapter,and then the monitor cable
(which is pretty heavy itself) there is a lot of weight and side torque on the video card. it also sticks out at least 4-6 inches and is bound to hit
something. The card failed about 15 minutes after I fired it up and I am in the process of trying to RMA it (with Gainward making this difficult)
Even if a replacement works ok I dont like the way I have to connect it to the monitor, and can forsee problems in the future. Is it possible I got
the wrong card? I havent read any mention of this board having multiple versions for different applications but maybe there are.
Any body have any ideas? does any one know if there are any monitor cables available that have a standard 15 pin serial connector on one end and
this goofy "DVI" 28+ pin connector on the other (thereby eliminating some of my sidewaise torque).
Instagib
1,344
No you got the right card. It has dual DVI's. Those are for LCD monitors. Its ok to use those adapters to hook into a crt monitor.
Maniac9127
417
Is the cable on your monitor hard-wired? If not, then you can get a special DVI-I to D-sub adapter like this one (tho 50 bucks for a cable is a rip). If it is hard-wired you'll have to stick with the adapter that's included with the card, or you could get a small extension cable.
DVI is a special port that is designed to give a purely digital source to LCDs, skipping the digital to analog conversion that's required for CRTs. The ports on the Gainward are DVI-I ports, incorporating both an analog and digital video source for both CRTs and LCDs on one port, so that they can have two digital ports and yet still have two analog ports, without having to have 4 ports on the backplane.
Good luck with the RMA though.
