Hi I have a question about Gainward 5900XT Ultra / Golden 1100 vs SAPPHIRE ATI RADEON 9800 PRO. I got the 5900xt from new egg and I don't know if this results below are normal and want to find out if I should return this card and get an ATI 9800 Pro. It is a good card for overclocking but it tends to look up uf you over cloock it too high. Right now I run it at 450 MHZ Core and 780 MHZ memory.
System specs:
- A7N8X-X" nForce2 400 Chipset Motherboard
- AMD Athlon XP 2500 Barton Core (oc 3200 @ 2.2 GHZ )
- 500MB RAM PC2700 333MHZ ( oc PC3200 400MHZ)
- Maxtor 80 GB 2MB Buffer 7200RPM Ata 133
- Thermaltake Case w / 8 fans and 540 Watt Power supply
- Gainward GeForce FX5900XT Ultra Golden Sample 1100 @ 450 MHZ and 780 MHZ
L (RUNNING Nvidia 61.77 drivers)
(Doom 3)
1024x768 / 32bit (High quality) no aa and no af - 30~15 fps and slide show when opening doors.
1024x768 / 32bit (Medium quality) no aa and no af works fine on average 60~40 fps and minimal lag when opening the doors.
800c600 (Medium) 60fps runs with no lag.
(Far Cry) - After I had to download the 1.1 patch
1024x768 / 32bit (High Quality) with Ultra High water - WOULDN'T EVEN RUN ( LOOCKS UP THE PC )
1024x768 / 32bit (Medium Quality) High Texture, Ultra High Water, ( Runs but lags some on big maps but playable)
1024x768 / 32bit (Medium Quality) all medium settings runs fine no lag
I'm not totaly satisfied with this results. Any different drivers I can try ? HELP !!
IS THIS NORMAL?? is ATI 9800 Pro Better in these results. Should I get IT or stick to Nvidia ???
Please tell me why if I should switch and if I'm going to see any noticable difference.
(Nvidia) - the one I got
http://www.newegg.com/app/View...=14-128-185&depa=0
(ATI) - Should I swap it for ATI ?
http://www.newegg.com/app/View...=14-102-268&depa=0
Any suggestions apreciated.
System specs:
(Doom 3)
