Gained weight while I had a broken foot and I need help losing it..
atybimf
2,390
Well, I broke my foot playing basketball and have had to wear a full leg cast for roughly 8 weeks. In that time, I gained probably 7lbs! Plus, I will be going to LA soon and I wanna get back into shape before surfing.
So, what should I do to lose weight. I am going to run a few miles everyday and work out again, but I need help with a good diet to help me lose about 7-10lbs in a short amount of time. Help!
Tylanner
5,481
7lbs?
is it that bigga deal?
just weight a bit, maybe if you weight a bit youd lose it.
hypn0tik
5,866
Originally posted by: atybimf
Well, I broke my foot playing basketball and have had to where a full leg cast for roughly 8 weeks. In that time, I gained probably 7lbs! Plus, I will be going to LA soon and I wanna get back into shape before surfing.
So, what should I do to lose wait. I am going to run a few miles everyday and work out again, but I need help with a good diet to help me lose about 7-10lbs in a short amount of time. Help!
Eli
Super Moderator | Elite Member
8
You have two choices.
You can either maintain your current diet and burn more calories, or maintain your current daily routine and eat fewer calories.
atybimf
2,390
Thanks for catching that. My bad.
Well, since I will start running and working out again, I think I should probably just take in less calories.
Paratus
17,399
15,220
You should lose 7-10 in less than 2 weeks especially with exercise. Hell I just cut out hitting the snack machines at work and second helpings at dinner and have lost ~13Lbs in 3 weeks.
Injury
13,066
Don't worry... the other girls won't notice as long as your ass fits in your same jeans and your high heels look good.
hypn0tik
5,866
You're welcome.
destrekor
28,799
359
how short is 'a short amount of time'.... starving yourself is always an option, but that diet plan can only be done for so long before its not healthy and needs to be replaced with a healthy diet plan
try eating healthy, and exercising....
but 7lbs? i dont think i'd notice the difference in someone, unless they were 127lbs and now they're 120lbs and 5'9"
atybimf
2,390
I only have a week and a few days..
That's my dilemma (sp?)
GTFO
atybimf
2,390
Update: Stepped on the scale - I officially gained 11lbs. I need to lose that in roughly a week. Keep in mind I'm not a very strong-willed person.
Paratus
17,399
15,220
GTFO
Should be enough time. Just don't starve your self . Drink water and cut out the cokes, do some running. It seems the first week is the easiest to lose a lot of weight. By the end of the diet your lucky to lose 1 lb a week but at the start 7lbs in a week and a few days should be doable.
atybimf
2,390
GTFO
Mmkay. I should be fine as long as I stick to it I suppose.
