Demo24
- Aug 5, 2004
- 8,356
- 9
- 81
Originally posted by: b3av3r
also the transmission is the huge weak link in the sti car. Any amount of boost/power and the tranny begins having problems, so maybe its more a weak component than a bad driver. Though I imagine some of it is a bad driver.
Two points here; firstly a 'weak' tranny it is not. The previous 5 speed was 'only' good for ~350ft lb or so of tq, but the 6 speed in the STi is much stronger. Secondly, a 'weak' tranny has nothing to do with how a driver shifts. If you slip the clutch, the key word is YOU.
I admit I am not an expert with either of these cars, but the few local sti guys I knew all had problems with their transmissions mainly due to launching hard and the transmission not being able to handle the launch.
All I was saying was if the tranny or the clutch were shot (or close to it) it can make driving a standard much more difficult and this could be some of the problem.
sorry but if they had issues with an STI 6spd transmission then they were doing some crazy stuff to that car! That is a very strong transmission, and I have actually never heard of one breaking. Usually the clutch will go out if you abuse it, but the weakest part is the axles.
Originally posted by: Vic
Clearly driver error. I always find it comical to see some punk who put a loud exhaust on his car when he clearly can't drive stick properly. I'd be embarrassed if it were me.
There's no reason to slip the clutch in a WRX, STI, or EVO for regular daily driving. It's not like they're low on power. Any of them can do a normal start off from just a blip above idle. For spirited driving, you might do just a split second slip in order to cushion for a high rpm launch, but that's it.
Actually the wrx is pretty torque less below boosting levels. You can get it going with out throttle on flat patches of ground, but it can be tricky. Hills are the worse, especially with passengers.
On mine I usually only slip first and thats to get it going reasonably well. I take my time on second but I don't slip it unless I'm in the dead spot of these gears which is when its too fast to get into first(wont physically go in) but a bit slow for second.
