OK, so I have a Belkin F5D7633-4 wireless router, which is connected through the ethernet port on my PC (wired). A couple of things don't want to work well though (Frostwire and PiMPStreamer for PSP), so I guessed it was because my ports wern't forwarded correctly. I checked this through ''http://www.utorrent.com/testport.php?port=[insertporthere]'', and every port I entered told me ''Error! Port [number] does not appear to be open.''
So, I went to portforward.com and tried to change my IP from static to dynamic, as it said I need to do this before forwarding. I followed this guide to do so: http://portforward.com/networking/static-xp.htm
After I restart my computer, my IP address remains the same, according to whatismyipaddress.com. Does this mean I have a static IP address?
After that, I used this guide to try and forward a few ports: http://portforward.com/english/routers/...orwarding/Belkin/F5D7633-4/default.htm
It wasn't too difficult, but I think I did something wrong, as when I test the forwarded ports using http://www.utorrent.com/testport.php?port=[insertporthere], it still tells me they aren't forwarded.
Anyone have any help, or advice on where I might have gone wrong? Sorry for the long post, and thank you.
