Gah computer problems suck
makken
1,476
Gah, i hate it when computers fail right when you need them the most.
Large project due tomorrow, all files are located on a laptop, and I can't seem to get it to boot now. It's running windows vista and the OS boots fine, but it hangs on the welcome screen, with a please wait sign, going for 15 minutes now. I can't log in or do anything.
Safe mode has the same problem - vista starts up then completely hangs on the login screen.
has anyone encountered this problem before in vista? know any solutions?
thanks
CKent
9,020
Google it with the make and model. I find prebuilts (Dells, HPs, etc. - and, by definition, laptops) have proprietary parts with specific problems. I just fixed a friend's Dell which had a stop error caused by faulty drivers for the proprietary SATA controller. Turns out this is a common problem with Dells build in 2005-2006 using this proprietary Intel controller. Updating the drivers would have worked, if it would boot up - but it wouldn't, not even in safe mode, not even with every unnecessary peripheral unplugged. In fact I couldn't even reinstall windows with all the peripherals attached, I had to disconnect one of the optical drives, one of the two sticks of ram, the sound card and the modem before it would let me get that far.
Exterous
20,582
3,785
Any external devices plugged in? I had a computer that would not start up with a specific printer plugged in (Worked fine with the other printer though)
Jeff7
41,596
20
Happened to me last semester. Finals were the next week, and my PC wouldn't boot. Checked the guts, and it turned out to be a bulging cap. A regular cap wouldn't do the trick, and no local vendors carried low-ESR caps. All my assignments were on the hard drives, which are in RAID 5, on a Promise SX4000 controller. I couldn't boot it on someone else's system, because the only one I had was on a really different motherboard (Socket A vs a P4 board), so WinXP bluescreened on bootup.
Just lovely. Fortunately, I had a laptop, and I at least had older copies of some of the notes I needed.
I wound up doing a system upgrade. Now I've got aluminum capacitors, hopefully I won't see any more of that bulging cap issue.
(Interestingly, where I work, we use video dubbing equipment. A digital video -> DVD recorder was acting up. Power supply had a bulging cap. Damn things are like weak mines.)
