Gah . . .. (Brita water pitcher broke!)
Dec 28, 2001
11,391
My water-filter-pitcher thingi broke . . .. More specifically, I have a huge crack on the part where it holds all the faucet water so it goes through the filter - I don't want to shell $20 for a whole new pitcher, so is there a replacement part I can buy?
Blue part on this thing is cracked
idNut
3,219
Welcome to the club, mine broke too. Brita, pssh, more like Brittle.
Kadarin
44,296
16
Bah.. I just drink tap water and have faith that my immune system will hold out..
Dec 28, 2001
11,391
So is there any way to replace this part? I have two other filters sitting there, and unless I can use them in a PUR filter, I'd hold out for a little while . . ..
Konigin
2,358
AH...the world is going to end!
Do those things really make the water taste better? I've never tried them.
MisterPresident
1,163
Not worth replacing just the part IMO. I doubt they even make them. I'd get a PUR filter for the faucet. Brita = Brittle, but I've never heard of anyon'es pur getting messed up.
Dec 28, 2001
11,391
I thnk they do - I'd get a PuR filter, but like I said, i still have 3 filters that I need to use . . . you guys think if I use epoxy to glue it together, it'd be okay? I'm pretty sure I won't be ingesting anything harmful . . . I hope?
Rkonster
1,737
My Pur broke, but then again, I dropped it 5 feet onto a tile floor. :D
dighn
22,820
4
the filter is not for filtering microorganisms
Dec 28, 2001
11,391
Anyhoo, my roommate said that as soon as water touches epoxy, even after it dried off, the stuff would almost immediately break down and I'd be drinking that stuff . . . any truth?
