GA-P35-DS4 Rev 2 Strange Problems.
jacc1234
392
I just completed a new build with the P35-DS4 and am having serious issues. The first issues began when I was installing Vista X64 after a very long setup there was a BSOD. I assumed it was my ram and after running memtest for a few hours found a faulty stick.
When I was trying to use my memtest boot cd I received a few disk boot errors and was unable to boot from the cd. After a few shutdowns the cd would finally boot. I replaced the sata cables for the HD and DVD drive and the errors stopped.
Now 1 RMA into the build and running on only 2GB of (RAM OCZ Reaper HPC Edition) I got vista x64 installed and everything was going well. Then the diskboot error returned. I tried different sata ports and the computer would boot. Then randomly it would stop booting untill a few hard restarts. They have since stopped but I dont know for how long. I installed the chipset, lan, and realtek HD audio drivers with out issues but now randomly my soundcard disappears. It does not show up on device manager at all when it is not working. I have had it work with both the Realtek and Microsoft sound drivers but it seems to have a mind of its own. I have reinstalled a few versions of the driver and am out of ideas.
I think my Mobo is just screwed and am dreading the RMA. The case is a P182 and it was not an easy install. I am looking for any ideas and help. The only odd thing that stands out is that i did not have any washers with the motherboard screws and i dont know if its grounding out.
Edit: Another strange fact. When installing my big typhoon I plugged the 3 pin connector into the 4 pin CPU-Fan slot on the mobo which should be fine but the fan would only spin intermittently even after disabling any type of "smart fan" settings in the bios. This is really starting to get under my skin. I am going to try vista and see how much might be software but any new Mobo recommendations would be good as well.
Thanks for the help.
Jacc1234
kalvinj
32
now i am scared lol i just bought one of those i am just waiting for it to come in :eek: i might be using vista 32 bit but not for sure on that i might stick with xp pro for a while longer... but yeah thats scary :eek:
buddhatb
219
I just hope this is an isolated incident since the DS4 was one of the mobo's I was deciding over.
Keep us updated.
Cheex
3,123
Keep us updated.
Me too.
isandu
41
...and when I thought I finally found the perfect Core 2 board for me... :((
I really hope you just had bad luck and that there's nothing wrong with the other boards.
Hope to hear from you soon.
de8212
4,021
ditto
Bobsled
343
Just finished building a new computer using this MoBo, a Q6700 and Crucial Ballistix but went w/ Win XP. Besides an initial small problem (my bad) very nice MoBo. Lots of features for the price. I would not over look it. Maybe the OP just got a bad apple. BTW, mine came with BIOS F6.
jacc1234
392
I think I simply got a bad board and it does not look like alot of other people are experiencing similar problems. I have decided to RMA it to the Egg and am going to go by frys to pick up another board so if i have any more issues I wont have to wait. I have decided to go with either a Asus P5k-E or the GA-x38-DQ6. I will keep you updated.
