Bios F7, E4300, 4GB of HP PC5300 sticks, Antec Sonata III (earthwatts 500), GF PCI-X 7300 (no PCI-X power adapter needed, must be a liteweight card), HD is ST SATA 7200.10 250GB, SATA Samsung DVD.
I see nothing bleeding edge about this hardware setup.
AHCI Mode Disabled (default)
SATA Port 0-1 Native Mode Disabled (I think that is default)
I have performed a "Load Fail-Safe Defaults" numerous times. I only change BIOS to boot to cd-rom before HD.
XP always hangs, dvd spins down, screen blank for 10 minutes before I patiently give up hope.
CentOS 5.1 was already installed on the HD and the system boots to it, and I think it only has a XEN kernel installed. Only the NIC doesn't work, I think that is kind of expected considering it was installed on other hardware. This system will boot to the CentOS DVD and an Ubuntu Desktop 7.10 CD without problems. I booted to the Ubuntu CD, it has that LIVE thing going and used numerous large apps, like OpenOffice, I browsed the Internet, no problems.
XP always hangs right after the "setup is inspecting your computer's hardware configuration." The CD is in pristine shape, I stays in that large envelope that MS supplies with it. It rarely even gets used. This is retail, not OEM.
I ran memtest from the Ubuntu CD for about an hour, it encountered no errors. Yea it didn't finish. It start it before bed.
From the Bios, the CPU has never been over 34c AFAIK, Intel stock cooler until I acquire better.
This is my first Gigabyte MB, is there something special I need to do here?
