- Jan 3, 2008
- 372
- 0
- 0
I just got my system built and every thing worked great, posted on first try and then installed windows everything went perfect.
After i got to desktop screen i couldnt get on internet so in installed motherboard CD drivers.
After that internet worked and i immediately started updating windows. Then i updated to windows explorer 7 and it continued updating.
Then it stated that all updates could not be installed and asked for restart. So i restarted and internet stoped working. When i click Explorer its a views normal except where yahoo page would normally be its just white.
Also when this window is up it freezes and wont let me close the explorer window but everything else works fine such as going into the start menue ect its just that explorer window will stay there.
I tried to update driver and it states new driver under system, hardware, device manager, network adapter.
Also i have an Netgear PCI ethernet card so i installed that and disabled onboard LAN driver and tried to install netgear drivers but still no go.
Under under system, hardware, device manager, network adapter it shows the netgear card and says its working properly but the internet wont work.
Any advice. Do i got to reinstall windows???
System in sig along with
GA-P35-DS3L
EVGA 8800GS
G Skill 800
E6550
THANKS
GA-P35-DS3L
EVGA 8800GS
G Skill 800
E6550
THANKS
