GA-EP45-UD3R OS install problem
Twista
9,646
So, i been going at this for over 3+ hours and no go. Windows will not install on my SATA drive. Vista gets stuck @ the screen after loading setup files and xp sp1 gives an error after it starts installing.
It installs fine on a IDe drive. I never heard of VISTA or SP1+ Xp needing sata drivers to work properly.
Anyone have an idea?
Twista
9,646
Update. Vista on the IDE drive can browse the Sata drive with no problems in windows.
However if i start the vista install with the sata drive it just hangs at 1 screen =[ WTFFFFFFFFFFFFFFFFFFF
Twista
9,646
Think im just going to return this POS as defective. I believe someone brought it back. Drove 1 hour to the tigerdirect main warehouse for nothing.
Brutus04
656
I have the same MB and installed WXP Pro w/no issues. Make sure your SATA is enabled in the BIOS and is listed as your 1st boot device.
