GA-965P-DS3 and Samsung SATA DVD RW low write speed
ntemples1
37
Hi everyone,
Please can someone offer some advice, I have the GA-965P-DS3 and a dual boot system with windows XP Pro and Windows Vista, I also have a Samsung 18x Sata DVD RW, but for some reason the drive only has a maximum write speed of 2.4x, but on the vista side it's up to 18x, I cannot understand why,
I was thinking i might have set it up wrongly in the bios, so I enabled ACHI and put the Sata ports 0-3 to native, but it hasn't made any difference,
Any advice would be fantastic,
Thanks in advance.
bka4u2c
551
That's weird about the reported difference in write speeds. I'm not sure about what media you are using but the highest DVD-RW write speed of I know of is 4X. My DVD-RW's are only 2.4X max but I've had mine for years.
ntemples1
37
thanks for the reply, the media I am using are DVD-R 8x, but even when there aren't any discs in it the write is still only 2.4, Do i have to install sata drivers for the dvd burner? I am unsure what to do when setting up the bios for sata drives only.
vailr
54
Is the DVD-RW connected to an (orange) Intel or (purple) JMicron port?
Are the latest drivers:
Intel Chipset [intel_inf_8401010beta]
and/or
JMicron Controller [JMB36X_WinDrv_WHQL_R1.17.21] installed?
Both at: www.station-drivers.com
Also: try uninstalling the DVD-RW from Device Manager, then reboot to re-install.
ntemples1
37
Lokan: No I don't have any issues with the device manager
Vailr: the Hard Disk is connected to the Purple Port (sata01) and the DVD Burner is connected to the orange port (sata03) (should i have them both on the same colour?
I will install the above drivers you gave me thanks guys for your help.
ntemples1
37
I have moved both drives over to the purple one Jmicron one,
In the Bios I have the following:
SATA Port 0-3 Native Mode: Enabled
Onboard SATA/IDE Device: Enabled
Onboard SATA/IDE Ctrl Mode: AHCI
are these configured correctly?
ntemples1
37
Have updated the drivers and no change. it's strange cause the maximum CD writing is 48x but the maximum anything with dvd is 2.4x
I am going to try moving both drives over to the orange (intel) ports now.
ntemples1
37
well it didn't seem to make any difference.... apart from i had to re-activate vista again through the phone ... which sata ports are best to use on this board?
Lokan
305
ntemples,
I don't have the board, so I can't comment on what SATA ports are better than others. I've typically been told to use the non-JMicron in the past, but each board may be different.
As to the reason why you're experiencing what you're experiencing, the only other options I can come up with would be to make sure you have the latest Firmware for the ROM drive. I have 3 DVD-RW ROM's on my PC, one from Pioneer (IDE), and two from Samsung (one IDE and one SATA); all three of them burn the same DVD-R or +R disc at different speeds due to their various states of Firmware.
ntemples1
37
Lokan: thanks for your help, i have updated the firmware of the DVD burner to the latest version, I agree about the different disks being detected at diffferent speeds by the burner, so I will try it out with some other brands of dvds.
As for the SATA setup, I have found that having both drives on the Jmicron (purple) ports seems actually slower on the vista experience test, it has dropped from 5.7 to 5.2, so I am stumped, I don't know wether or not to put them both on the Intel Ports now.. have any other people using the GA-965P-DS3 set up their sata drives this way?
Lokan
305
You're welcome. I wish I could come up with a better solution. Burning seems to be so hit or miss when it comes to consistency :/
