GA-7VTXE & Pinnacle Studio PCTV-Pro
jontart
hello:
To upgrade an older system (300 - Celeron PII,64 sdram, HD 6 gigs, Matrox Mistique Video
car), I purchased a GigaByte 7VTXE motherboard, Athlon XP 1600 processor, 256K ddram,
prophet 4500 TV-OUT graphics card (64MB), HG seagate 40 gigas, 7200 r.p.m., and
a PCI TV TURNER/CAPTURE BOARD: Pinnacle Studio PCTV-PRO.
I need to make sure the motherboar matches the TV card within problems.
I'm having a lot of trouble setting up the TV. I checked the TV-card and it's OK
(run perfectly in the older system). I'm sure there are not problems with the drivers
of the TV-card or any configuration options. I have tried all the drivers and other stuff that they say on
Pinnacle's website.
There are not any different software or hardware in the PC.
If the compatybility is not 100%, I change the PC-Card and try other one. But I need to do it quickly.
I hope someone can give me some advice on that.
Thanks.
Did you upgrade your OS to XP at the same time? I don't think the XP drivers for that card are working very well yet...
