GA-7VRXP or 7vrx have problems with ti 4200 or 4400 or 4600?
shortnugly
168
Saw a GA-7VRX on ebay with a note that the card doesn't work with geforce4 4200, 4400 or 4600 cards.
linky
Any truth to this? or any other issues with the 7VRXP?
WTT0001
1,510
Yes, the rev. 1 and some of the rev.1.1 boards do on both, mainly due to not enough power getting to it, some also have stability problems due to power also. My 1.1 was perfectly solid, at least until the bios went bad, sent it back for the 2.0 rev. and it is perfectly solid :D
shortnugly
168
Wtt0001 , thanks for the info. I'll be sure to hunt down the 2.0
Also, would you have rather had the GA-7VRXP instead?
Dec 24, 2001
55
I just got my gigabyte Ga-7VRXP MB and it runs my athlon 2000+ at about 1700 MHz pretty stable and I am using a GeForce Ti4200 graphis card. I have Rev2
