My CPU is Athlon XP 1900 which is supposed to run on 1600MHz if the FSB is 133MHz. The problem is that I cant make the FSB run on 133. I know that in order the FSB to run on 133, Switch1 on the motherboard should be turned off. But when I do that the PC doesn't want to start at all. Sometimes just shows the VGA BIOS version sometimes shows nothing. I have upgraded the motherboard BIOS fo Version F6 but still is not working. Could you please give me some clue what may be the problem?
Thank you.
GA-7VRX rev. 2.0, BIOS 7VRX F6
AMD Athlon XP 1900
Micron PC2700 DDR
Chaintech G442 GF4 MX440 64RAM
WD 400BB
Sony 24xCDRW
SB Live! 5.1
Thank you.
AMD Athlon XP 1900
Micron PC2700 DDR
WD 400BB
Sony 24xCDRW
SB Live! 5.1
