GA-7DXR+Win2k+XP cpu problems
JoeDaddy
Banned
Jul 7, 2000
1,819
Ok here's the problem.
I upgraded my 1.3ghz cpu to an XP 1800+. I loaded F7 bios before I swapped cpu's. I left the clk_sw to 100mhz by accident and it boots up as XP 1150mhz. If the FSB is set for 100mhz Windows 2k will boot just fine. But as soon as I set it for 133/266fsb Windows 2k will not boot. When it set i for 266fsb it does see it as a XP 1800+. It compleates the bios check and everything just fine, but at the point where it would normally begin booting windows it just hangs there with a blinking cursor. It doesn't matter if Top Performance is enabled or disabled.
GA-7DXR w/ F7
256MB PC2100 Crucial Reg. ECC
2x30GB IBM 75GXP in Raid 0
Radeon 64mb w/ VIVO
3com 3C905B
onboard sound
Win 2k w/ SP2
Any ideas?
