This will benefit any 8800 series Owner but (G92) Owners will benifit the most as the GPU seems to run a bit cooler than the G80.
I have replaced the Thermal Interface on my GPU and it seems to be about 5-7 Deg. C Improvement just from that.
There is more opportunity for improvement also.
After getting my card apart this is what the interface material looks like, and it is an improvement from the past materials...
http://www.imagecross.com/mysp...r-s.php?id=8134001.JPG
After cleaning the hard Grey crap off there was this GPU with a very nice mirror finish (G92) Use Isopropyl Alcohol and a Q-Tip to clean.
http://www.imagecross.com/mysp...r-s.php?id=9587002.JPG
http://www.imagecross.com/mysp...r-s.php?id=5790003.JPG
The cooler has been improved by the addition of pads cast into the body of the cooler over the VRAM...The Thermal tape there is .003-.005 in. in thickness
http://www.imagecross.com/mysp...r-s.php?id=2106004.JPG
This copper insert can be an opportunity for improvement by lapping if you are so inclined.... I did not have the time
As far as Thermal materials... use non-conductive material, and be very sparing in the application. On the GPU I prefer Shin Etsu...
I did not do my Vram, as I did not have the material that I personally prefer. (AS Ceramique) the gap at the VRAM is such though that other materials could also be used as long as they are non conductive, and clean-up easy.
