G860 Temperature Range
4eigner
So, I'm running Prime95 and my cpu temp is at 86C max so far. Have the Foxconn RM2-H2 Barebones kit and G860 stock HSF.
Oh, Prime has been running for about 16 hours. Is the temp range ok?
Alright, sweet! I was just a bit worried since I'm not used to seeing cpu temps that high.
Thanks, doods!
Its all amatter of where its measured. Its been just as high if not higher previously. You just didnt know due to no sensor there 😉
