G15 macro problems
Maxily
I have a very strange problem with my G15 keyboard when I play World of Warcraft. I have used this keyboard for over a year now, first on Windows XP. It worked perfect back then. I could create simple or more complicated macro's and they worked fine, both in Windows as during WoW.
Recently, I have bought a new system with Vista Ultimate 64 bit. I downloaded the new drivers / software and everything seems to be running fine. I can create a macro, and when I press the G-button associated with that macro, it works.
But, there is a problem with the macro's when I play WoW. Some macro's work in WoW while others do not. This has me believe that there are 2 kinds of macro's with the G15. You can either record a serie of keypresses, or you can just assign a single keypress to a G button.
Example:
If I set the G18 button to the numlock button, not with creating a macro, but just by assigning a keypress, then that button works fine in WoW.
However, when I create a macro to press the numlock key, it does not work in wow. Either by making a macro via the profile-software thingy, or by pressing the MR key, then a G button, then the numlock key and then the MR button again.
Real macro's do not work when I play wow.
I have already reinstalled the software / drivers for the keyboard, but it did not have any effect.
Has anyone else had this problem or knows a fix / solution for this?
