I just pulled the trigger on the 128GB model and one of the Athena 5.25-inch backplanes.
http://www.newegg.com/Product/...x?Item=N82E16816119006
Originally posted by: Viper GTS
I hope the sites that are testing these drives are letting them reach steady-state performance before publishing their data.
Originally posted by: Denithor
You do want to disable automatic defrag because that will wear out the drive faster (these drives don't get fragmented & more writes = shorter lifespan).
Which is why I'm waiting until AT reviews the drive.
Can we get a review around here? Pretty please?
Another adventurous soul! :thumbsup:
Originally posted by: bradley
Both the 256GB and 126GB drives are in stock, 38 and 56 remaining respectively. I wonder how long before Intel drops their prices. Although there's already a scathing review on the 126GB drive involving stuttering. I'm waiting for more real-world reviews myself.
:laugh:
Yes - we know - that's where most of the info in the OP came from...
:beer:
Originally posted by: taltamir
if it has a raid0 of two jmicrons inside (using a THIRD chip...) and you put it in raid0... is it raid 00?
I've been doing a lot of SSD testing in the last few weeks, & every model I've seen slow considerably once every block has been written at least once. This results in drastically lower performance, and greatly increased access times.
Q. Do SSDs get slower as they get older?
A. This is a complicated issue. Multiple factors can contribute to performance degradation during the life span of a SSD. Most significant is the internal fragmentation of the data stored on the flash media. Unfortunately, there is currently no way to measure it externally. Like I said above, fragmentation is not crippling to a SSD to the extent that it is for HDDs. Benchmark programs might be able to quantify the difference between optimal and fragmented internal layouts, however the user experience should not degrade substantially (at least, not with our drives). Normal usage also should not cause worst case internal fragmentation the way a benchmark program might. There are several ways that SSD optimized file systems should be able to partially alleviate this problem (see later question on file systems).
... even on a spindle drive i dont recommend defragging, since it does more harm then good in most scenarios there as well.
Do you have any hypothesis as to why this is happening?
It's upgrade time for my system, and I've already upgraded the video card. CPU is next. I was hoping to put in an SSD as the OS drive...but I don't want to pay an arm and a leg, and end up with crappy performance from the drive after a few weeks.
EDIT: Google gives this interview of an Intel engineer at hardocp.
So is it wear levelling (i.e.'internal' fragmentation) that is leading to the performance degradation over time? Doesn't sound too good :/
I'm shore they use two controllers for porting not to improve throughput by division.
It's a known limitation. The very first time you write to a block on an SSD, you can just write out the data to the block in question. Every time after that, you would have to then read the block to a cache, erase the block, and then rewrite it with the changed contents. Smarter controllers can hide the additional latency somewhat, and I would hope that more reputable manufacturers are rating their drive write speeds with the latter process in mind.
