Last year, I built a small "server" with an Atom D510/Intel MB, 1GB DDR2, 320GB WD 5400 RPM disk, in an Antec ISK300-65 case.  It runs Linux "headless"...command-line only, no monitor, keyboard, etc.  Typical power measured at the outlet: 22W.
I needed to build a second, similar "server", and thought I would try the AMD E-350. The build ended up being the MSI E350IS-E45, 4GB DDR3 (1.5V), same 320GB WD Scorpio blue model, this time with the Antec ISK300-150. Same type of Linux install. Typical power measured: 32W. A 10W increase for more CPU, more RAM, and who knows what impact of the 150W supply (vs the 65W of the other case).
(FYI...the fan on the E-350 is noisy. I ended up setting "target CPU temp" to 60C, and min fan speed to 12.5%, and this seems to keep the noise at a more acceptable, low "whoosh". If I were to do the second build again, I would go with a fanless E-350 solution, and back to the ISK300-65 to get back to a near-noiseless solution).
 Facebook
Facebook Twitter
Twitter
