Sorry to resurrect an old thread, but I was interested in the observations about how a motherboard can trigger throttling by artificially maxing out the temp sensor to 255 degrees.
However, are there other ways that the motherboard can trigger throttling, without using this trick?
I'm seeing some behavior that may suggest throttling, but can that happen without spiking the temp to 255 degrees?
It's an FX-6300 chip on a motherboard that has 8+2 phase power and supports up to 140W (Asus M4A89GTD PRO/USB3 using beta BIOS 3030).
The symptom is that I can set the overclock to 4 GHz, 4.5GHz, and 4.8 GHz, but when I examine the plots of the frames per second recorded by FRAPS for these different speeds, there are parts where the plots coincide. Also, I get better FPS when I set the CPU fan to 100%, so I'm starting to think that maybe there is a more gradual throttling with temp. However, the temps seemed to be around 30 degrees and the CPU usage was less than 100%, so I can't see how the fan setting would help things as there shouldn't be throttling under those conditions unless I misunderstand (maybe it was cooling my VRMs?)
