SlowSpyder
- Jan 12, 2005
- 17,305
- 1,001
- 126
Yea, as long as you have CnQ enabled idle power will be still very low. My CPU drops as low as 1.4GHz and .88v at idle.
Hmmmm, explain a bit more if you can.
Are you saying the theory is that I could get 4.3GHz at the same or equal TDP as the 8350? Would I also get the benefit of lower idle consumption than the 8320/8350?
I'm not familiar with editing pstates. If it's too technical then I'm not sure I'm comfortable with it. I can follow a guide for most things and I have overclocked in the past so I know what changing multipliers and FSB along with voltages entails. I worry that will mess with the ECC process, too, though.
Well since you have the 8350 coming, you can do it with that instead of the 8320e.
But yeah, basically, you can hit 4.3 GHz (or 4.2 on the 8350) without chewing up that much more than the listed TDP for the chip. CnQ *should* work for you regardless of what is the base clockspeed of the processor. All you're doing is disabling turbo and picking the max turbo state as your base clockspeed.
Editing pstates is another way to accomplish this, especially for processors that don't behave properly when the base clockspeed is altered in the BIOS (such as my Kaveri; CnQ doesn't work in Windows when I set the base clock to anything but auto, but it will in Linux, go figure). The pstates represent all the different clockspeeds the chip can reach depending on usage level. So, it has all the low-power states for being idle and all the turbo states. Vishera has . . . 5 pstates I think. It's just a command-line tool where you enter the name of the pstate (p0, p1, etc) then plug in the CPU multiplier and then the voltage and you're done.
You can probably get your Vishera to go into low-power states during idle with an altered base clockspeed, so no worries.
The only reason I recommended the 8320e is that you can probably hit 4.3 GHz with an 8320e at around 1.3v vcore. The 8350 - assuming all the 8350s out there are still coming from before wk29 of 2014 - will probably take 1.36-1.38v for 4.2 GHz (your mileage may vary).
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=9494388
Go with an 8310.
95W , 7700 passmark, $119.
We need, like, a site banner telling people to ignore cpuboss links.
Maybe we should have the forum auto-filter them out like they do certain image hosts.
That was my plan for the last 6 months, but as of Thursday and for the previous month or so the 8310 was "In Store Only". I had been following to see if it would come back in stock and finally gave up. I checked before I ordered the 8350, otherwise that's the way I woulda gone.
Son of a........
Oh well, with the 8350 I won't have to deal with the wondering if I should have gotten the faster CPU for just a few bucks more and by the time S&H from TigerDirect are included, the 8350 was only about $25 more.
http://www.cpu-world.com/Compare/302/AMD_FX-Series_FX-6100_vs_AMD_FX-Series_FX-8350.html
2 more threads, 21% more clock, handles more instructions...
he FX-6100.
Where the system used to idle at about 62-65W this one really wants to lock in around 81-89W. I ran the Passmark CPU tests on them both and the FX-6100 peaked at around 174W but the 8350 peaked at 226W.
Wowza!
Everything about this CPU is a lot higher than the FX-6100.
That's the bad news, but what did I expect? It's 125W vs. 95W TDP.
You can tame that with some undervolting. What's the default vcore on it right now, and have you messed with voltages or clockspeeds yet?
I cna't believe people are complaining about 95w. At full load 4.3ghz in Prime I'm using 350w. At idle it's 130. At 4.6ghz it's 420w.
Woooeee that's some serious power draw right there. You got a leaky chip, no doubt about it.
Yikes, what is you voltage set to? I don't start seeing those kinds of numbers until I'm up into 5GHz+ range.
Dual graphics cards are a big draw, of course. But what is the change you see between idle and full CPU load (leave GPU's at idle)?
