Im confused and need some help.
Just completed my first pc build yesterday. After running some stress tests etc today i noticed while idle my cpu was averaging at 46c. Which i do believe is a bit high for a Gelid GX-7 cpu cooler. I was expecting mid 30's as its a hot chip.
After 16 mins of stress testing all cores checked out as ok and the temp was at 62c.
Is this ok?
Or should i look into reapplying the heatsink and thermal paste?
My system spec:
AMD FX-8320 @ Stock
Asus Sabertooth 990fx R2.0 MB
8GB DDR3 1333Mhz Memory.
Msi 7870oc (with dual fan config)
corsair cx750m psu.
Antec 900 V3 case. With 2 front 12cm fans, 1 24mm top, 1 12mm back fan.
Help please! bit nervous as this is my first build.
Is this ok?
My system spec:
AMD FX-8320 @ Stock
corsair cx750m psu.
