I've searched the net trying to find typical temperatures for the FX-53 with a Cooler Master Hyper 6 heast sink but have not found anything, yet. I am wondering if anyone out there could give me their typical temps. I listed my specs in my signature, but the pertinent items are that I have two Vantec Stealth fans in a push-pull configuration and have used Arctic Silver 5. (I spread the compound instead of applying just the bead and letting the heat sink spread it. I didn't see the Arctic Silver directions until afterwards.) I have the FSB overclocked to 230 MHz (can't go much higher because of the stupid SATA 1/2 issue
) with a CPU multiplier of 11 to get 2.53 GHz. I use 1.55 volts to the core, and 2.8 volts to the memory. I am using MBM 5 to monitor the temps and I think that I have the latest "official" bios for my MB. My idle cpu temps have been around 42-44 degrees celsius. Full load temps running Prime95 climb to 56 degrees celsius. Last night, after running for a while and then playing HL2 for an hour, temps were 60 degrees celsius. System temps idle around 37-39 degrees celsius but I've seen them as high as 46 degrees celsius after loading. Case temp is usually a consistent 20-21 degrees celsius. The cpu and system temps seem too high to me considering the HS and fans. I have almost all cables sleeved and I tried to push them out of the way for maximum air flow. Does anyone have any similar experience or advice?
P.S. Now that I am getting addicted to overclocking, anyone out there think the Aquagate or Big Water cooling systems would do much better?
Thanks for your help.
