...Well I seem to have figured some of this out. First of all, I remove all my
USB devices and rebooted and Windows found the scanner again and it's fine
now.
Also, using a wizard I found at the microsoft site and walked through it and
found that the shut-down problem was caused by my dial up adapter. I removed
it and now Windows shuts down normally. I am on cable so I only need my
ethernet adapter. I assume I will need the dial-up adapter to send a fax
via modem right? If so I guess I'll have to add it then?...not sure about
that. one.
Only bug now seems to be that OE and IE 5.5 takes a very long time to
load....man if it's not one thing it's another
) It loaded like lightening
just after I reinstalled everything...????
Btw I have an Asus P2-99B motherboard with a 440ZX chipset.
Thanks for any help!
Gary
now.
that. one.
Gary
