Original Post:
I ended up getting the Sonata case. Everything came in monday, put it all together.... and press the power button. No go...
Fan on the case spins for 1/2 a second and dies down. Then the power has to be puilled for it to work.
Each component is thoroughly tested: ended up that it would boot up if the Floppy Pwr connector to the Video card (Radeon 9500) is connected, it will not boot up. With the power connector pulled, it boots till the point where the error comes up saying"You havent connected the power cord!". I think it is a power problem. Disconnect HDDs, CD drive... only CPU, mobo, mem, vid card on the power supply now. Still no go
So I obviously think the vid card is fuxored, and put it back in the old machine. Old machine boots up fine with it!!! I'm like WTF!!!???!
So now I think the mobo is scrooed. Get another vid card (GeForce3 Ti200), and the thing boots up. Install windows and I come straight here to bitch and ask for help. (WoW IS installing in the bkground though
So... any ideas guys?
Cliff notes: NEED HELP
Need you guys to look over the components and comment...
Finalised & ordered:
Memory: Corsair 1GB kit
Proc: A64 3000+
Mobo: DFI Lanparty UT 250Gb
Case: Antec Sonata
I've got almost everything else for the system (HDD, vid card, DVD burner). This is not intended to last me very long (1+ yr max)... so recommendations on how to cut prices are welcomed. It the DFI lanparty a better board? I am going with safe bets here. Maybe gonna do a little overclocking.
I need to find a case for this though.... any recommendations? I need something cheap... maybe something I can put a good power supply into. Again... need peoples input here.
